Built from rugged 5mm hardened steel, these locking brackets deliver versatile security across a range of applications. Designed for padlocks with shackles up to 12mm in diameter, each unit features sturdy fixing bases (45mm wide x 38mm high) and should be mounted using heavy-duty coach bolts (not included).
Abus
ABUS 115/100 Locking Brackets Pair
| Web Attribute Set | Padlocks & other locks |
| EAN Barcode | 4003318541179 |
