The Stanley Deep Pro Organiser comes with 10 removable storage components allowing you to organise your smaller accessories for efficiency, inside and outside of the box. With the transparent lid you can easily view what is in your toolbox and where it is without the need to rummage through. With the waterproof seal you can be assured no water or foreign particles will enter. The organiser is also fitted with a textured polypropylene handle to give you a more secure grip and, with the heavy duty metal latches, you can be confident the toolbox will not accidently fall open. For easy transportation, the two metal side slide latches allow you to attach your organiser to another. Size: 446 x 356 x 116mm deep.
Overall L x W x H 446 mm x 356 mm x 116 mm
Manufacturer Part Number 1-97-518
Web Attribute Set Organiser Cases
EAN Barcode 3253561975189
