The UJK T-LOC Case & Foam Cutout for Dovetails is fitted with precision cut foam to securely hold your essential components of your dovetail jig accessories. Whether you're storing cutters, a guide bush adaptor or other small UJK parts, the UJK Dovetail Jig Accessory Case keeps everything neatly in place.
Perfect as a dovetail jig cutter case, it ensures your cutters are safely stored and easily located when needed, no more misplaced parts or cluttered drawers.
British made, this case is tough enough for site or workshop use. Like all UJK T-OC cases, it’s fully stackable and compatible with the wider system, locking securely with the single-handed T-LOC catch.
If you own the UJK Dovetail Jig, this dovetail jig accessories case is the perfect companion – keeping your kit together, protected and always ready to go.
Case dimensions: 265mm X 180mm X 70mm.
Overall L x W x H 265mm X 180mm X 70mm.
Web Attribute Set Organiser Cases
EAN Barcode 5052511143344
