A flush mounted no-volt-release switch with the added benefit of a prominently positioned lock-on emergency stop button. It is capable of switching up to 12A 230V. It has a no-volt-release feature, but not overload protection. It is suitable for use with additional remote safety switches or interlock switches on doors or access panels. Size is 75 x 120 x 110mm deep with two fixing holes on 110mm centres. Please note, you will need 4 x 5mm crimp on female spade connectors. Rated at IP54 protection against dust ingress and water splashing.
Axminster Workshop
Axminster KJD18-9 NVR Switch 230V 1ph
| Web Attribute Set | Motors & Switchgear |
| EAN Barcode | 5052511064762 |
