The KJD12 230V switch is commonly used on small woodworking machines. Rated at 16 amp, it will be suitable for induction motors up to 1.5hp. Simply connect using insulated spade terminals, the connections being clearly marked for input and output. It is a no-volt-release type of switch, providing safety in the event of an interruption of power. Requires a rectangular hole approximately 40 x 60mm, the switch being secured by 2 mounting bolts (not supplied). Fitted with a dust cover and having positive action push buttons.
KEDU KJD12 Switch 230V 1ph
| Web Attribute Set | Motors & Switchgear |
| EAN Barcode | 5052511046256 |
