3 PEAKS
3 Peaks Engineer's Screw Removal Pliers
SKU: 113771
£14.15 £16.65 Save £2.50
  • Removes damaged and stripped screws
  • Ideal for low-profile truss head screws
  • Unique vertical groove jaw design
  • Powerful side grip on screw heads
  • Grips screw heads from 3mm to 9.5mm
  • Cuts copper wire up to 1.5mm diameter
  • Comfortable grip handles
  • High-quality Japanese manufacture
  • Compact 160mm overall length
  • Ideal for repair and maintenance work
3 Peaks Engineer's Screw Removal Pliers are designed to grip and remove damaged, stripped, rusty and stubborn screws that cannot be removed with a screwdriver. Particularly effective on low-profile truss head screws, they provide a simple and reliable solution for repair, maintenance and workshop tasks.
The specially shaped jaws feature a unique vertical groove and concave profile that grips screw heads securely from the side, allowing excellent purchase on damaged fasteners. This innovative design works equally well on truss head, pan head and partially rounded screws, helping remove fixings that would otherwise be difficult to extract.
Manufactured in Japan from high-quality steel, the pliers have a maximum jaw capacity of 9.5mm and can securely grip screw heads from 3mm to 9.5mm in diameter. Hardened cutting edges are capable of cutting copper wire up to 1.5mm diameter, adding extra versatility. The pliers measure 160mm overall length, making them compact and easy to carry in a tool pouch or toolbox.
3 Peaks is renowned for producing innovative Japanese hand tools that combine precision engineering with practical solutions for everyday workshop challenges.
Ideal for woodworkers, engineers, electricians, mechanics and DIY users, these versatile pliers are perfect for removing damaged, seized or stripped screws from furniture, hardware, machinery and workshop equipment. A practical addition to any toolbox, they provide a reliable solution when conventional screwdrivers can no longer get a grip.
Web Attribute Set Pliers
EAN Barcode 4960225170062
