Sold out Sale
Arbortech
Arbortech Mini Carver MKII
SKU: 109686
£261.25 £275.00 Save £13.75
£217.71 Excl. VAT
  • 1,000W powerful smooth running motor
  • Extended head reaches otherwise inaccessible spaces
  • Versatile for carving, sculpting and sanding
  • Variable speed for best results
  • Efficient dust collection when connected to vacuum
  • Ideal for medium wood removal and detailed carving
  • Supplied with carry bag, mini industrial blade, 15 sanding discs (5x 80, 180, 320 grit), rubber sanding pad, dust extraction outlet, anti-vibration handle and spare carbon brushes.
The Mini Carver MkII is fitted with Arbotech’s latest 1,000W motor. Whether shaping, sculpting or sanding it has plenty of power and more. The Arbortech Mini Carver is a hugely versatile power carving tool. From rough shaping to sculpting, texturing, and sanding, the Mini Carver can do it all. The Mini Carver’s narrow, extended neck offers greater access into small areas. This is a perfect tool for medium to small sculptures and carvings as well as adding detail and helping finish larger works. The Arbortech offers power, value, performance, efficiency and versatility.
It uses 50mm diameter blades and sanding discs, The relatively compact size and long neck gives you better control and visibility. Variable speed (6,000 to 18,000 rpm) gives you full control whatever the task: Setting 5 to 6 is for high-performance wood carving and sculpting.​ 3 to 4 for aggressive sanding on rough surfaces. 1 or 2 for smooth, finishing sanding.
When sanding the flexible rubber backing pad allows you to follow the curve, refining the shape and finishing.
The dust extraction outlet when attached to a suitable vacuum is highly efficient. A great bonus when sanding, in keeping airborne dust out of the workshop.
The Arbortech Mini Carver MkII is supplied with a 50mm tungsten carbide Mini Pro Carving Blade, a vibration reducing auxiliary handle, Rubber Backing Pad (Sanding), 15 assorted sanding discs (5 x 80, 180, 320 grit), Dust Extraction outlet, set of spare carbon brushes and a robust Arbortech storage bag.
Motor Power 1,000 W
Web Attribute Set Power Carvers
EAN Barcode 9313478902907
