Arbortech
Arbortech Precision Carving System
SKU: 107553
£118.75 £125.00 Save £6.25
£98.96 Excl. VAT
  • Detail power carving, sculpting and sanding kit
  • Fits Arbortech Power Carving Unit or M14 angle grinder
  • Consists of 2 x 15mm carving heads and a 16mm drum sander
The Arbortech Precision Carving System is designed for free form carving, sculpting, detailing and texturing. The system consists of a Universal Base, which fits onto the Arbortech Power Carving Unit or a 100mm or 115mm angle grinder with an M14 thread. Into this base you have the choice of attaching either the Ball Gouge, Barrel Carver or Drum Sander. The system also contains two sanding sleeves, hex keys and instructions. The tools are very well designed, the universal base provides support and stability during the cutting process. Changing from one option to another is simple.
The Precision Ball Gouge is similar to its larger cousin. This smaller 15mm version enables you to carve tighter radii and get smaller spaces. Use it to create smooth hollows and dips.
The Precision Barrel Carver (15mm diameter) offers controlled carving on the outside of the barrel and can create right angle corners. It can be used on the side, at an angle or upright to bore into wood.
Finally the Precision Drum Sander, (16mm diameter) smooths and finishes as well as gentle shaping and refining. It comes with a 60 and a 120 grit sleeve.
Web Attribute Set Power Carving Accessories
EAN Barcode 9313478902600
