Sold out Sale
Arbortech
Arbortech TURBO Plane Blade
SKU: 502570
£118.75 £125.00 Save £6.25
£98.96 Excl. VAT
  • Rapid freehand wood sculpting, planing and trimming
  • Leaves a smooth finish requiring minimal sanding
  • Durable carbide teeth ensuring long blade life even in hardwoods
  • Easy to sharpen using a diamond 400 grit diamond file
  • Excellent control, balance, and safety (no cutting teeth on blade periphery)
  • Ideal for free-forming convex and concave shapes
  • Fits Arbortech Power Carving Unit and any 100mm(4) or 115mm(4.1/2) angle grinder
  • Can be used with guides and templates for accuracy
The Arbortech TURBO Plane is a great addition to the very popular Arbortech range of products. Using this cutter is just like adding a rotary plane to your angle grinder. Proving very popular with woodcarvers and sculptors, the Arbortech TURBO Plane removes stock very quickly and leaves a great finish. Can be used on green or seasoned timber. The three durable tungsten carbide blades hold their edge well but can be easily sharpened using a diamond file when necessary. The 100mm diameter blade, attaches to the Arbortech Power Carving Unit and most 100mm(4) and 115mm(4.1/2) angle grinders.
Web Attribute Set Power Carving Accessories
EAN Barcode 9313478320015
