The Arbortech TURBO Plane is a great addition to the very popular Arbortech range of products. Using this cutter is just like adding a rotary plane to your angle grinder. Proving very popular with woodcarvers and sculptors, the Arbortech TURBO Plane removes stock very quickly and leaves a great finish. Can be used on green or seasoned timber. The three durable tungsten carbide blades hold their edge well but can be easily sharpened using a diamond file when necessary. The 100mm diameter blade, attaches to the Arbortech Power Carving Unit and most 100mm(4
Arbortech
Arbortech TURBO Plane Blade
| Web Attribute Set | Power Carving Accessories |
| EAN Barcode | 9313478320015 |
