Axcaliber
Axcaliber Adjustable Finger Joint Set
SKU: 506656
£99.98 £121.98 Save £22.00
£83.32 Excl. VAT
  • A fully adjustable glue joint cutter
  • One of the strongest ways of jointing solid timber
  • Use either side to side (joint) or for end to grain to end grain
  • Profile extends glue line for extra strength
  • Up to 5 TCT slotting cutters can be stacked at one time
  • Use to produce 1 to 5 finger joints
  • Board thickness 11-36mm
  • 6mm finger depth
  • This cutter set is for use in router tables only
Bearing guided adjustable finger joint set that can produce up to 5 fingers per joint. This type of glue joint extends the glue line giving extra strong joints. Fully adjustable you can produce single and multiple joints by changing the cutter configuration. Board thickness: single 11-16mm, two 16-21mm, three 21-26mm, four 26-31mm and five 31-36mm. Finger depth 6mm with a feathered profile. Please note, the timber needs to be machined square before jointing. Supplied with one bottom cutter, 5 x finger cutters, ball bearing guide, shims, spacers and washers. 1/2 shank arbor. Storage case.
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 36 mm
D = Overall Diameter 40 mm
Web Attribute Set Jointing Router Cutters D: 40 X: 36
EAN Barcode 5052511063284
