Axcaliber
Axcaliber Adjustable TCT Boring Bit
SKU: 501990
£88.88 £107.88 Save £19.00
£74.07 Excl. VAT
  • Clean splinter-free cut, shearing action
  • Fully adjustable with a durable tungsten tip
  • Set the size required, lock in place and cut
  • Movable cutter with raduations, and cutting spur
  • Suitable for hard and soft wood
  • Cordless or mains tools and when working in the lathe
  • Size range 22 - 54mm
  • Overall length is 100mm, working length 70mm
Precision boring bit with the ability to recess or cut straight through, makes this a unique type of Forstner bit. Fully adjustable with a durable tungsten tip, the cutter has an outer scribe for a very clean precise hole. There are two adjustable wings that are used depending on the hole size. Size range 22 - 54mm. 12.7mm shank. Overall length is 100mm, working length 70mm.
Web Attribute Set Forstner & Sawtooth Cutters
EAN Barcode 5052511057702
