Designed for a first class result in all natural timbers and man-made boards, this blade is the perfect choice for professional use. It is particularly suited for mitre saws and would also suit workshop circular saws where a fine cut is required, particularly in laminate or faced boards.
The 5
Axcaliber CutPro circular saw blades use the latest production techniques and the finest materials. The blades feature micro-grained TCT tips. The resin filled, laser cut plates substantially reduce noise while cutting. A faint tensioning ring halfway across the plate indicates where each blade is individually pre-stressed, to guarantee smooth running.
The bore size is 30mm, various bore reducing bushes are available.
