Axcaliber
Axcaliber Edge Moulding Router Cutter 5
SKU: 666197
£43.68 £48.68 Save £5.00
£36.40 Excl. VAT
  • Highly versatile edge-moulding cutter
  • Produces skirting, plinths, pelmets, frames and trim
  • Use all or part of the profile for greater variety
  • Precision made on multi axis CNC machines
  • High shear-cut angle for cleaner finish
  • PTFE coating helps cutter to remain free of resin
  • 1/2 shank
This is a particularly versatile moulding cutter. It will produce traditional looking skirting, plinths, solid wood light pelmets, picture frame and trim. The bearing guide makes it suitable for curved work. Using this cutter in a hand held router is one option, but it is more effective in a router table for running lengths of moulding. By using different portions of the profile, the cutter can give a variety of moulding designs.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 41.5 mm
D = Overall Diameter 35 mm
R = Radius 3.2 mm (1/8")
Web Attribute Set Edge Moulding, Cornice & Handrail Router Cutters D: 35 R: 3.2 X: 41.5
EAN Barcode 5052511030453
