Axcaliber
SKU: 105229
£26.18
£21.82 Excl. VAT
  • Manufactured at Axminster using advanced CNC machining
  • Detailed quality checks are performed at each stage of manufacture
  • A blade which consistently cuts straighter, has harder, longer-life teeth
  • Gives a superior finish to the work
  • One of the few companies worldwide able to offer a fully guaranteed weld
  • The weld is annealed to remove any brittleness and danger of fatigue
Made in Britain Yes
Bandsaw Blade Length 3,352 mm (132")
Bandsaw Blade Width 25.4 mm (1)
Bandsaw Blade Tpi 3
Bandsaw Blade Type High Carbon
Web Attribute Set Bandsaw Blades
EAN Barcode 5052511107919
