Axcaliber
Axcaliber Kitchen Worktop Cutter
SKU: 107254
£12.98 £16.98 Save £4.00
£10.82 Excl. VAT
  • Great value TCT worktop cutter, 51mm depth of cut
  • For use with kitchen worktop jig and 1/2 router
  • Clean finish in laminate and solid wood worktops
A great value cutter for a one off job or those times when it may not be a good idea to use your best high quality expensive cutter. This 1/2 TCT router cutter will cut solid wood and laminate kitchen worktops, leaving a clean finish for a close fitting joint, when used with a worktop jig and 1/2 router. Twin flutes ensure smooth and efficient cutting. With a cutting depth of 51mm it is ideal for general worktop cuts.
N.B. The cutter does not have a bottom cut.
Pack Quantity 1
Web Attribute Set Straight Router Cutters
EAN Barcode 5052511123216
