Axcaliber
Axcaliber Twin Flute Straight Cutters with Bottom Cut Insert - 1/4"(6.35mm)
SKU: 341159
£17.58 £20.78 Save £3.20
£14.65 Excl. VAT
  • Twin cutting edges for fast clean cuts
  • Ideal for grooves, rebates, housings
  • Available in metric and imperial sizes
  • PTFE coating helps minimise resin build-up
Twin flute straight cutters are by far the most commonly used router cutter. Supplied with a bottom cut insert they are also most suitable for for fast and effective plunge work with two parallel cutting edges, they produce an excellent clean finish. They have many uses cutting grooves, rebates, housings or dadoes etc. Twin flute straight cutters are also a good choice for shallow mortices, such as hinge recesses. When selecting cutters always choose the shortest cutter that will give the depth you require. Shorter bits minimise vibration, cut cleaner and give a longer tool life.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 25.4 mm (1")
D = Overall Diameter 16 mm (5/8")
Web Attribute Set Straight Router Cutters D: 16 X: 25.4
EAN Barcode 5052511019083
