Axminster 63mm Dust Extraction Kit
SKU: 410063
£101.98 £119.98 Save £18.00
£84.98 Excl. VAT
  • Especially for the smaller workshop
  • Ducting package complete with elbows, blast gates and adaptors
  • 8 x 915mm lengths of tube (63mm diameter)
  • 4 x T-joints
  • 3 x 45 joiners
  • 2 x 90 elbows
  • 16 x pipe joiners
  • 5 x plastic blast gates
  • 10 x wall clips
  • 100mm to 63mm adaptor
  • Additional parts available separately
A ducting package complete with elbows, blast gates and adaptors for connecting up your machines to a workshop extractor. Simply fix a horizontal pipe to the wall or ceiling with the clips supplied and then take branch pipes to exactly where the extraction points are needed in the workshop, using the T-junctions and 63mm flexible hose. Attach a vacuum extractor and away you go! The kit consists of 8 x 915mm lengths of tube (63mm diameter), 4 x T-joints, 3 x 45 joiners, 2 x 90 elbows, 16 x pipe joiners, 5 x plastic blast gates, 10 x wall clips and a 100mm to 63mm adaptor. If the kit does not have enough components then additional parts are available separately.
EAN Barcode 5052511020461
