Axminster 75mm Quick Release Bit Holder 1/4"
SKU: 113319
£3.73 £4.98 Save £1.25
£3.11 Excl. VAT
  • Spring loaded sleeve locks the bit securely
  • Quick release for fast bit changes
  • Pull back sleeve to release
  • 75mm in length
  • Holds standard 1/4 hex drive bits
This quick release bit holder is 75mm in length and holds 1/4 hex screwdriver bits. A spring loaded sleeve locks the bit securely in place. Simply pull back the sleeve to release for a change of screwdriver bits.
Web Attribute Set Hex Drive Bits
EAN Barcode 5052511142057
