This set of four, 75mm long sanding drums will help you get more use out of your pillar drill or woodturning lathe. The drums are a resilient rubber fitted with an abrasive sleeve. Turning the nut located on the base of each drum, slightly expands the rubber and secures the abrasive sleeve. The diameters are: 25.4mm (1
Axminster Set of 4 Drum Sanders
| Abrasive Material | Aluminium Oxide |
| Abrasive Backing | Cloth |
| Pack Quantity | 4 |
| Web Attribute Set | Drum Sanding |
| EAN Barcode | 5052511127467 |
