Axminster Set of 4 Drum Sanders
SKU: 108513
£36.54 £42.98 Save £6.44
£30.45 Excl. VAT
  • Drum sanders for use in a pillar drill or woodturning lathe
  • 4 diameters: 25.4mm (1), 50mm (2), 63mm (2.1/2) & 75mm (3)
  • Includes 80 grit and 120 grit sleeves
This set of four, 75mm long sanding drums will help you get more use out of your pillar drill or woodturning lathe. The drums are a resilient rubber fitted with an abrasive sleeve. Turning the nut located on the base of each drum, slightly expands the rubber and secures the abrasive sleeve. The diameters are: 25.4mm (1), 50mm (2), 63mm (2.1/2) and 75mm (3). Partially used sleeves can be removed and kept for use at a later date. The drums come with two sets of sleeves, 80 grit and 120 grit. Replacement sleeves are readily available. Each drum has a 12.5mm shank. Maximum recommended speed 1,500rpm.
Abrasive Backing Cloth
Pack Quantity 4
Web Attribute Set Drum Sanding
EAN Barcode 5052511127467
