Axminster Straight Edge & Taper Jig
SKU: 114155
£44.99 £49.98 Save £4.99
£37.49 Excl. VAT
  • Woodworking jig for straight and taper edge cutting
  • Achieve smooth, clean cuts with ease
  • Compatible with standard 19mm mitre slots
  • Hold-down clamps ensure secure grip for any workpiece
  • For use with table saws and bandsaws
The Axminster Straight Edge and Taper Jig makes straight and tapered cuts simple and repeatable. Ideal for home workshops where users may not have a Planer Thicknesser, this versatile jig fits into a standard 19mm mitre slot on your table saw or bandsaw. It glides smoothly along the slot, keeping your workpiece accurately aligned with the blade for clean, controlled cuts. Particularly useful for straightening rough or wavy edges, the jig also makes tapered cuts straightforward – ideal for creating tapered chair or table legs.
The supplied slider bar is mounted to the jig so that the edge of the jig sits close to the blade. This helps support the workpiece as it passes through the cut, reducing tear-out and producing a cleaner finish. With nine mounting points, the slider bar can be positioned to suit different setups and workpiece sizes, giving you greater flexibility when using the jig.
Two adjustable hold-down clamps can be positioned anywhere along the jig, allowing you to securely hold different sizes and shapes of workpiece. The adjustable end stop helps keep the workpiece firmly in position and prevents it from drifting during the cut.
A comfortable handle provides steady control as you feed the jig through the blade, helping you achieve smooth, consistent results.
A versatile addition to any workshop, this woodworking jig provides an easy way to achieve accurate, repeatable cuts without the need for a Planer Thicknesser.
Web Attribute Set Saw Bench Accessories
EAN Barcode 5052511146970
