The thin rip jig makes repetitive ripping of thin strips safer and easier than any other method. Made from heavy duty aluminium extrusions, the jig locks securely in any 19 x 10mm mitre gauge slot. The built-in scale helps you make fine adjustments. The ball bearing holds the stock firmly against the fence, allows smooth feeding and makes repositioning a simple operation. Also, a very handy jig for a bandsaw, allows curved work to be done easily and accurately.
Axminster Thin Rip Jig
| Web Attribute Set | General Machine Accessories |
| EAN Barcode | 5052511054817 |
