Axminster Thin Rip Jig
SKU: 501146
£26.98 £29.98 Save £3.00
£22.48 Excl. VAT
  • Makes repetitive ripping of thin strips easy and safe
  • Cuts to the left of the blade, preventing burning, binding and kickback
  • Made from heavy duty aluminium extrusions with a built-in scale
  • Locks into any 19 x 10mm mitre gauge slot
  • Can be used for curved work on a bandsaw
The thin rip jig makes repetitive ripping of thin strips safer and easier than any other method. Made from heavy duty aluminium extrusions, the jig locks securely in any 19 x 10mm mitre gauge slot. The built-in scale helps you make fine adjustments. The ball bearing holds the stock firmly against the fence, allows smooth feeding and makes repositioning a simple operation. Also, a very handy jig for a bandsaw, allows curved work to be done easily and accurately.
Web Attribute Set General Machine Accessories
EAN Barcode 5052511054817
