Axminster Universal Mobile Base
SKU: 110977
£121.02 £186.18 Save £65.16
£100.85 Excl. VAT
  • Exceptional mobility and stability
  • High-quality steel construction
  • Supports up to 450kg
  • Versatile wheel system
  • Adjustable dimensions for machines
This Universal Mobile Base is designed to provide exceptional mobility and stability for your workshop equipment. Constructed from high-quality steel and finished with a durable powder coating, this mobile base ensures long-lasting protection against wear and tear. It features a robust design that can support a maximum load of 450kg, making it suitable for a wide range of heavy machinery and workstations.
One of the standout features of this mobile base is its versatile wheel system. It includes two fixed wheels and two castor wheels, allowing for smooth and effortless movement across your workshop floor. The castor wheels can be easily raised with screw-in feet, securing the base firmly in place when needed. This ensures that your equipment remains stable and secure during use.
The mobile base is designed to accommodate various machine sizes, and is supplied with 6 support bars (4 long measuring 545mm, 2 short measuring 455mm). These can be configured into the following two options:
Option 1: 2 x long bars + 2 short bars. Minimum size 485mm x 575mm, maximum size 670mm x 880mm.
Option 2: 4 x long bars. Minimum size 582mm x 582mm, maximum size 760mm x 880mm.
The modern design and enhanced functionality of this mobile base make it an essential addition to any workshop, providing both convenience and reliability for your heavy-duty machinery.
Web Attribute Set General Machine Accessories
EAN Barcode 5052511134366
