Axminster Wide T-Rule
SKU: 109958
£9.34 £10.98 Save £1.64
£7.78 Excl. VAT
  • Designed for dead-on accuracy with the included 0.5mm mechanical pencil
  • Thin construction avoids parallax issues, improving the accuracy of your projects
  • Suitable for end/edge marking, parallel and perpendicular line drawing, and vertical measurements
  • The T-Bar ensures accurate alignment and measurements, with easy adjustments if necessary
  • Length: 200mm, depth: 70mm
The Axminster Professional Wide T-Rule is a meticulously designed tool that ensures error-free marking for enhanced project precision. It simplifies precision marking and measuring, whether you're working along the edge or end of your workpiece, or need to draw lines parallel or perpendicular to the edge.
The wide rule has been specifically tailored for various marking and measuring applications, and the 70mm width allows for increased accuracy across more varied woodworking projects.
Its slim design minimises parallax errors, and the T-Bar alignment ensures accurate measurements. The T-Rule comes fully assembled, but if adjustments are needed, the T-Bar can be easily repositioned against the indexing lip before tightening to maintain accuracy. The tool is essential for any project requiring precise measurements and markings. Supplied with a mechanical pencil and refills for added convenience.
Web Attribute Set Rules
EAN Barcode 5052511132546
