The Axminster Woodturners Light is ideal for close up, detail work. It has a flexible 14 x 530mm neck making it fully adjustable to suit your desired location and features a super bright white 12W Multi LED bulb. The base is magnetic so is easily attached to your machine. It has an all metal construction. Due to the low wattage LED bulb, this light generates limited heat. Perfect for use in a darker workshop where more light is needed.
| Web Attribute Set | General Machine Accessories |
| EAN Barcode | 5052511138920 |
