The Bahco 319 Professional Hacksaw Frame is a lightweight yet robust hacksaw designed for accurate, efficient cutting. Its steel-core frame provides strength and rigidity, while the well-balanced design helps deliver straighter cuts with less effort.
A compact profile improves access when working in confined spaces, and the integrated blade tensioning mechanism allows quick adjustment. The comfortable non-slip handle with front grip provides excellent control, while the alternative 55° blade mounting position makes it easier to perform flush cuts close to surfaces.
Trusted by professionals worldwide, Bahco is renowned for producing high-quality hand tools that combine durability, innovation and user comfort.
Supplied with one fitted 300mm (12
