Bahco
Bahco 59/S54BC Colour-Coded Bit Set, 54 Piece
SKU: 112676
£14.98 £17.98 Save £3.00
£12.48 Excl. VAT
The Bahco 59/S54BC Colour-Coded Bit Set contains a wide selection of bits suitable for universal use. Each bit is made from high-performance alloy steel. Supplied in a durable carry case. Contains: 8 x 25mm Phillips Bits: PH1, PH2(x4), PH3 and PH2G(x2)6 x 25mm Pozidriv Bits: PZ1, PZ2(x4) and PZ32 x 25mm Slotted Bits: 4.5 and 5.5mm16 x 25mm TORX® Bits: TX10(x2), TX15(x2), TX20(x4), TX25(x2), TX27, TX30(x4) and TX405 x 25mm TORX® Tamper-proof Bits: TTX10, TTX15, TTX20, TTX25 and TTX305 x 25mm Hexagon Bits: 3, 4, 5, 6 and 8mm 2 x 25mm Robertson Bits: #1 and #22 x 125mm Phillips Bits: PH1 and PH22 x 125mm Pozidriv Bits: PZ1 and PZ23 x 150mm TORX® Bits: TX20, TX25 and TX30 1 x Magnetic Universal Bit Holder 1 x Magnetic Quick-Release Bit Holder1 x Socket Adaptor 1/4.
Web Attribute Set Socket Sets
EAN Barcode 7314150337613
