Bosch
Bosch GKF 12V-8 Brushless Router Trimmer 12V (Body Only)
SKU: 104398
£157.98 £163.98 Save £6.00
£131.65 Excl. VAT
  • Ergonomics: compact with full control when used one-handed
  • Cordless freedom: ideal for final trimming anywhere on site
  • Brushless EC motor: increased battery runtime and tool lifetime
  • Fine depth setting: micro adjustable for precise adjustment
  • Spindle lock: for easy and quick cutter changes
  • Drop detection: stops the tool running when dropped
  • Finger guard: prevents accidental contact with cutter
  • Supplied with a 1/4 collet
  • 3 year warranty available (registration required)
This cordless router is extremely compact with a shape designed for easy single-handed use.
The Bosch GKF 12V-8 router fits perfectly in the 12V woodworking range of Bosch Professional tools and is fully compatible with the Bosch professional 10.8/12V batteries. This cordless compact router gives you the freedom you need when routing and trimming. It features the latest brushless EC motor technology giving you longer runtimes and a long tool lifetime. The small size and low weight offer a unique grip for complete control even when used one-handed. The large baseplate ensures increased stability.
The GKF 12V-8 has both fast initial, coarse cutting depth adjustment and micro depth adjustment for precise fine-tuning. For additional safety, a drop detection sensor shuts off router should it fall and a finger guard prevents accidental contact with the rotating cutter.
Supplied with a 1/4 collet. This is a body only tool supplied without batteries and charger.
Battery Voltage 12 V
Collets Supplied 2026-04-01 00:00:00 +0100
Rating Trade/Professional
Spindle Lock Standard Feature
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 73 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] <2.5 m/s² [1.5 m/s²]
Plug Fitted UK 3 pin plug
Cutter Speed 13,000 rpm
Web Attribute Set Cordless Routers
EAN Barcode 3165140909822
