Bosch
Bosch Impact Control Drill and Screwdriver Set 35 Piece
SKU: 107249
£36.98 £39.98 Save £3.00
£30.82 Excl. VAT
  • High performance bit set for heavy-duty use
  • Suitable for drill drivers, combi drills and impact drivers
  • 26 x 1/4 hex impact bits in pozi, Phillips and Torx
  • 8 x Multi-construction drill bits 3 to 8mm
  • 1 x 1/4 hex, Quick Release, Universal bit Holder
  • Tough storage case
A 35 piece bit set designed for use with all impact drivers, combi drills and drill drivers. This set is perfect for situations requiring heavy-duty solutions.
The robust case contains twenty-six extra-tough 1/4 hex screwdriver bits. The bits are S2 Modified Steel with an extended, heat treated torsion zone. These features make them extremely sturdy for long-lasting, especially when used in impact drivers. Bit types include Pozi, Phillips and Torx.
The eight multi construction drill bits ranging from 3 to 8mm are suitable for drilling in a wide variety of materials such as masonry, brick, light building materials, multi-layer materials, ceramics and tiles, wood, plastic, and metals. Lastly, the set includes a 1/4 hex, quick release, universal bit holder.
Specification:
20 x 25mm 1/4 hex bits:
PH1 x 1, PH2 x 4, PH3 x 1, PZ2 x 3, PZ3 x 1, T15 x 1, T20 x 3, T25 x 3, T30 x 2, T40 x 1.
6 x 50mm 1/4 hex bits:
PH2 x 1, PZ2 x 1, T15 x 1, T20 x 1, T25 x 1, T30 x 1.
8 x Hex-9 MultiConstruction drill bits:
3mm x 1
4mm x 1
5mm x 2
6mm x 2
8mm x 2
1 x 1/4 hex, quick release, universal bit holder
Web Attribute Set Screwdriver Bits
EAN Barcode 3165140881777
