The Bosch S1122HF wood and metal sabre saw blade has a standard 0.9mm thickness and length of 225mm. These 2 factors give it excellent flexibility allowing flush cutting of nails, pipes etc. A strip of HSS steel welded to a high carbon steel backing makes this a good choice where the blade may encounter nails within the wood. The teeth have a 2.5mm pitch (10 tpi) to make short work of cutting nails metal fastenings. It has a cutting capacity of up to 175mm.
Bosch
Bosch S1122HF BiM Sabre Saw Blades Flex Wood & Metal (Pkt 5)
| Blade Type | Bi-metal |
| Tooth Pitch \ tpi | 2.54 mm \ 10 tpi |
| Intended Use | Bi-metal blade cuts wood or metal with soft nails and fastenings. |
| Web Attribute Set | Sabre Saws Blades Jigsaw Blade Type: |
| EAN Barcode | 3165140093576 |
