Cabinet Hinge Installation Jig & Bit
SKU: 510010
£10.49 £13.98 Save £3.49
£8.74 Excl. VAT
  • Spot-on placement for cabinet hinges
  • 35mm short pattern sawtooth bit
  • See-through plastic template
A simple kit consisting of a 35mm short pattern sawtooth bit and a transparent plastic template with which to mark the positions of the holes for the hinge and the screw fixing holes. Designed more for occasional use, such as when replacing a few doors in an existing kitchen.
Web Attribute Set Drills for Hinges
EAN Barcode 5052511023592
