Chroma Craft
Chroma Craft Peel-Off Stencils
SKU: 108227
£1.00 £14.98 Save £13.98
£0.83 Excl. VAT
  • Create and develop your own artistic designs
  • Peel-Off stencils, self-adhering highly flexible film
  • Precision die-cut, reuseable, suitable for dye or paint
Chroma Craft Peel-Off Stencils are part of the Signature Series by woodturner Nick Agar. Chroma Craft has worked closely with Nick to design and produce these stencils to help you develop your own artistic designs.
The stencil material is specially formulated for use with low saturation solvent or acrylic paints. It is a self-adhering flexible film that can conform to complex shapes and can be repositioned. Simply peel off from the backing sheet and apply to the surface that you want to colour. They are precision die-cut and reusable so you can use them again and again. The translucent film allows clarity for layering techniques as well as visibility of the pattern.
The stencils can be used with any combination of techniques including airbrush, dauber or roller with Chroma Craft dyes, paints and markers.
Each stencil pack contains both positive and negative images so you can have a lot of fun creating your own designs. Each stencil sheet is approximately 200 x 275mm with multiple sized cut-outs (approx. 10 per sheet), 2 sheets per pack.
