A router can be used for many tasks and this kit gives even more versatility, supplied with 2 bases, plunge or fixed that can be easily swapped over making it 2 routers in one covering many applications. Very compact and solidly built this machine handles well and is easily controlled whichever base you are using. The powerful variable speed 900W motor has full wave electronics to ensure the selected speed is maintained under any load for the best finish and there is a spindle lock for ease of cutter change. Each base fits to the motor body with a quick lever. The plunge base has precise depth adjustment and a five position adjustable turret for stepped/repeated plunge cuts, moulded handles ensure a positive grip. The fixed base has a wide depth ring collar that moves up and down the scroll in the motor body allowing for depth setting, fine adjustment is made with a thinner calibrated ring. The machine is supplied with a kit of accessories including: This machine is supplied with two fences, a fixed base fence and the plunge base fence, 2 dust extraction adaptors, 1/4
DeWalt
DeWALT D26204K 2 in 1 Router (1/4")
| Collets Supplied | 2026-04-01 00:00:00 +0100 |
| Spindle Lock | Standard Feature |
| Sound Power Level LwA [Uncertainty K] | 88 dB(A) [2.8 dB] |
| Corded or Cordless | Corded |
| Sound Pressure Level LpA [Uncertainty K] | 77 dB(A) [2.8 dB] |
| Vibration Cutting Wood [Uncertainty K] | 6.8 m/s² [2.7 m/s²] |
| Motor Power | 900 W |
| Plug Fitted | UK 3 pin plug |
| Cutter Speed | 16,000 - 27,000 rpm |
| Voltage | 230 V |
| Web Attribute Set | Routers |
| EAN Barcode | 5035048315767 |
