Sale Web exclusive
DeWalt
DeWALT DCK266P2 Brushless Combi and Impact Twin Pack 18V (5.0Ah)
SKU: 104406
£239.98 £279.98 Save £40.00
£199.98 Excl. VAT
  • 18V XR twin pack with combi drill and impact driver
  • Latest generation brushless motors for high durability DCD796 XR Combi Drill
  • 2nd generation brushless technology for 30% more power and excellent efficiency DCF887 18V XR Brushless Impact Driver
  • High power brushless motor ensures heavy applications are completed quickly
  • Long battery runtimes, improved power transmission
  • Shaped ergonomic handles with a rubberised comfort grips
  • LED work lights illuminate working area
  • Includes DCB115 XR multi-charger and 2 x 18V 5.0Ah XR batteries
  • Comes in a TOUGHSYSTEM™ DS150 Toolbox
The DeWALT DCK266P2 18V twin pack comprises DCD796 XR Combi Drill, DCF887 XR Impact Driver, DCB115 XR Multi-charger, 2 x 18V 5.0Ah XR batteries and TOUGHSYSTEM™ DS150 Toolbox.
The DCD796 XR brushless combi drill features brushless motor technology. This offers greatly increased power and efficiency, much longer battery runtimes and a long maintenance free service life. The 2-speed all-metal gearbox provides improved transmission and longer tool life. A 15-position adjustable torque control and the variable speed trigger give you complete control in all screwdriving applications. The DeWALT DCD796 XR has a compact, lightweight design making it far easier to use in confined spaces. The ergonomic handle with a rubber grip over mould improves comfort and control. A super bright LED light with a 3-position switch illuminates your work area.
The DeWALT DCF887 18V XR brushless impact driver features 3 speed settings. The variable speed trigger offers additional control, making work faster, easier and avoiding material and fastener damage. Capable of delivering up to 205Nm of torque, it drives larger screws effortlessly. The DCF887 impact driver has a 1/4 hex 'drop in' keyless hex driver to allow quick, one-handed bit changing. Lightweight and well balanced, this impact driver is actually very heavy duty. The compact design and is easy to use in tight spaces. The ergonomic handle has a rubberised comfort grip reducing vibration and fatigue. The triple LED halo light ring gives excellent illumination inside cupboards.
The DCB115 XR multi-voltage charger is portable or wall mountable. An LED indicator displays the battery charge status: charged, charging, power problem and battery too hot or too cold conditions. It can charge a 2.0Ah battery pack in 30 minutes.
The TOUGHSYSTEM™ DS150 Toolbox is tough and durable featuring heavy duty metal hinges and latches for durability, dust tight and water resistant construction and bi-material top handle. The DS150 is also stackable, for even better versatility.
Battery Capacity 5.0 Ah
Battery Voltage 18 V
Rating Trade/Professional
Batteries Included 2
Battery Type Li-ion
Corded or Cordless Cordless
Chuck Capacity Combi: 13 mm
Chuck Type Combi: keyless Impact: 1/4 hex
Web Attribute Set Cordless Combi & Impact Kits
EAN Barcode 5035048667880
