The DeWalt DWE625KT 1/2
The variable speed has preselection from 8,000 to 20,000 rpm. Electronic speed control keeps the speed constant under load. With such a powerful machine, the soft start feature is a must.
The easy to reach plunge lock lever puts control at your fingertips. The router has one touch plunge lock, which engages the lever and allows free plunge movement. Self lubricating phosphor bronze bushes ensure smooth plunge action, whilst the 3 turret stop and fine height adjustment allows for repeatable, accurate cuts. The parallel fence also features fine adjustment. Twin LED lights illuminate the working area around the cutter.
Dust extraction is particularly efficient via the direct airlock dust port. In addition the clear lower dust tube and cowl allows an unobstructed view.
The base uses the same geometry as the previous DW625, all current accessories and attachments fit perfectly.
Supplied with: 1/2
Note: This router is fitted with an Anti Restart Safety Switch and is incompatible with a seperate external NVR switch.
