Einhell
Einhell Multi Tool & 2.5Ah Battery/Charger Kit 18V
SKU: 114749
£69.96 £97.96 Save £28.00
£58.30 Excl. VAT
  • Part of the Power X-Change battery system
  • Includes 2.5Ah battery and charger
  • Tool-free quick-release accessory changes
  • Magnetic 12-pin accessory holder
  • Variable speed control for different materials
  • 3.2° oscillation angle for precise working
  • Vibration-reducing battery mount
  • Soft grip for improved comfort and control
  • Ideal for sawing, sanding and scraping tasks
The Einhell TE-MG 18/1 Li Cordless Multi-Tool is a versatile solution for sawing, sanding and scraping applications around the workshop, home and jobsite. Powered by an 18V Power X-Change battery, it offers cordless freedom and the flexibility to tackle a wide range of renovation, installation and maintenance tasks.
A tool-free quick-release system and magnetic 12-pin accessory holder allow fast accessory changes and flexible positioning, while variable speed control helps match performance to the material being worked. The 3.2° oscillation angle enables precise cutting and sanding, and the vibration-decoupled battery mount and soft grip surfaces improve comfort during extended use.
Part of Einhell's Power X-Change battery platform, this multi-tool is compatible with all Power X-Change batteries and chargers, offering a convenient and expandable cordless system.
Supplied with;
1 x Einhell TE-MG 18/1 Li Cordless Multi-Tool
1 x 2.5Ah Li-ion Battery
1 x Battery Charger
1 x Delta Sanding Pad
9 x Sanding Sheets (3 x P60, 3 x P80, 3 x P120)
1 x Scraper
1 x Plunge-Cut Saw Blade (Wood & Plastic)
1 x Segment Saw Blade (Wood, Plastic & Soft Metal)
Battery Capacity 2.5 Ah
Battery Voltage 18 V
Batteries Included 1
Battery Type Li-ion
Corded or Cordless Cordless
Web Attribute Set Cordless Oscillating Tools
EAN Barcode 4006825672947
