Einhell
Einhell TP-MG 18 Li BL Multi Tool 4.0Ah Battery, Charger & Case
SKU: 114146
£119.98 £131.98 Save £12.00
£99.98 Excl. VAT
  • Brushless multitool with long runtime and 10‑year motor warranty
  • Variable speed, 3.2° oscillation and LED light for precise work
  • Quick‑release, tool‑free accessory changes with magnetic mount
  • Includes 4.0Ah battery, 3A fast charger and accessories
  • Supplied in durable, stackable Einhell E‑Case S‑F
The Einhell TP‑MG 18 Li BL‑Solo Multifunction Tool is a powerful and versatile solution for cutting, sanding and scraping across renovation, repair and construction tasks. Its PurePOWER brushless motor delivers more power, longer runtime and greater durability than conventional carbon‑brush motors. Register online to activate the 10‑year motor warranty.
With variable speed electronics and a 3.2° oscillation angle, this multitool offers controlled, precise and material‑friendly work. A locking on/off switch supports long operating periods, while the vibration‑decoupled tool head and Softgrip surfaces ensure comfortable, low‑fatigue handling. The integrated LED light provides excellent visibility in darker working areas.
Tool‑free accessory changes are made quick and simple thanks to the quick‑release system and magnetic tool adapter. A 12‑pin accessory interface ensures secure positioning and flexibility. As part of the Power X‑Change family, the tool is compatible with all batteries in the PXC range.
Includes a 3‑year Einhell warranty with registration within 30 days.
Supplied Accessories
Delta sanding shoe with Velcro fastening
Diamond segment blade for tile joints
HSS segment blade for wood, plastic and soft metals
BIM plunge‑cut blade for metal
HCS plunge‑cut blade for wood and plastic
Specifications
Oscillating Speed: 22,000–40,000/min
No Load Speed: 11,000–20,000/min
Oscillation Angle: 3.2°
Sandpaper Size: 93 × 93 × 93 mm
Weight: 1.08 kg
The high‑performance 4.0Ah battery features a 7‑in‑1 ABS Active Battery Management System, 3‑stage LED indicator and a microprocessor that actively monitors temperature and voltage. A repair mode revives deeply discharged batteries, while premium lithium‑ion cells minimise self‑discharge. A rubber‑coated housing protects from impacts, and the ergonomic recessed handle ensures comfortable removal and handling.
The compact fast charger is wall‑mountable and reduces downtime with efficient charging technology. Intelligent charging management provides maximum safety, while the refresh mode restores deeply discharged batteries. Charging status is clearly displayed via a 6‑stage LED indicator.
The Einhell E‑Case S‑F offers safe storage and easy transport for tools and accessories. As part of the modular, stackable E‑Case system, it provides flexible organisation for equipment, attachments and consumables. The case measures 44 × 33 × 13 cm and supports loads up to 25 kg.
Its secure locking system allows multiple cases to be firmly connected, and thanks to its special design, it can be opened even while stacked. Made from tough polypropylene, it is splash‑proof, heat‑resistant and impact‑resistant. Two foldable ergonomic handles provide comfortable carrying, and an integrated lock point allows the case to be secured with a standard padlock.
Supplied with a 18V 4.0Ah Power X‑Change Li‑Ion Battery, 3A Quick Charger and E‑Case S‑F.
Battery Capacity 4.0 Ah
Battery Voltage 18 V
Sound Power Level LwA [Uncertainty K] 87 dB(A) [3.0 dB]
Batteries Included 1
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 79 dB(A) [3.0 dB]
Web Attribute Set Cordless Oscillating Tools
EAN Barcode 5052511146581
