The Festool Abrasive Systainer with 80 x 133mm Granat Abrasive is a highly organised and versatile solution for all your sanding needs. The comprehensive set includes 100 abrasive sheets in various grit sizes (P60, P80, P120, P180, and P220), making it ideal for a wide range of applications and ensuring you have the right grit for any task. The Systainer keeps your abrasives sorted by grit size, making it easy to quickly find the right sheet.
Granat abrasives are designed to avoid clogging and ensure a long service life, especially suited for VOC varnishes and hard substrates. Granat with its tough aluminium oxide and hard ceramic grit is long lasting and can be used on many different materials. The Systainer protects your abrasives from dust, water, and bending, and can be easily transported and connected to other Systainers. The Systainer keeps your abrasives sorted by grit size, making it easy to quickly find the right sheet. The Systainer protects your abrasives from dust, water, and bending, and can be easily transported and connected to other Systainers. Supplied in Systainer SYS3 M 112 with inlay. Fits; RTS 400, RTSC 400, RS 400.
Supplied in a SYS3 M112 Systainer with 100 x 80 x 133mm sheets in total, 20 each; P60, P80, P120, P180, and P220.
