The Festool DTSC 200 cordless delta sander combines maximum mobility with exceptional surface control, making it ideal for sanding large areas, tight corners and edge‑close work. Powered by an 18 V battery system, it allows unrestricted movement whether you’re working in the workshop or tackling hard‑to‑reach locations on site.
A standout feature of the DTSC 200 is the integrated LED light ring, which illuminates the work surface and highlights uneven areas as you sand. Two selectable light modes allow either full or dimmed illumination, while additional lighting settings can be customised via the Festool App, including brightness adjustment and delayed illumination for surface inspection after sanding.
Driven by the durable EC‑TEC motor, the sander delivers smooth, low‑vibration performance with minimal noise and reduced maintenance requirements. The large delta sanding pad enables efficient material removal while remaining precise enough for detailed work in recesses and corners. A carbide‑tipped sanding pad brake prevents uncontrolled pad rotation when idling, protecting the surface from scratches and reducing the need for rework.
The DTSC 200 operates on an 18 V battery platform and runs at an idle speed between 6,000 and 10,000 rpm with a sanding stroke of 2.5 mm. It features a 145 × 195 mm interchangeable sanding pad and a 27 mm dust extraction connection. The tool weighs 1.5 kg without accessories and produces a sound pressure level of 82 dB(A) and a sound power level of 90 dB(A). Vibration levels during sanding average 3.0 m/s² in accordance with EN 62841‑2‑4 standards.
Festool is synonymous with precision engineering, intelligent system design and professional‑grade performance. Every tool is developed to integrate seamlessly with Festool accessories and dust extraction systems, delivering cleaner results, improved efficiency and long‑term reliability for demanding users.
The DTSC 200 can be paired with Festool 18 V battery packs for flexible runtime options and connected to Festool CLEANTEC dust extractors for efficient dust removal. Using the Festool App, lighting functions can be further customised to suit different sanding tasks and inspection requirements.
Supplied as body only with sanding pad, edge protector, chip collection bag and SYS³ M 187 Systainer for organised storage and transport. Part of Festool 18V Family of tools.
