Buying a Festool SYSTAINER storage case is a sound investment. The design ensures your tools or accessories are safe, well protected, organised and easily accessible. SYSTAINERS help you work smarter.
This SYS 3 T-LOC has a 10-compartment insert designed to store 150mm abrasive discs. It provides an efficiently organised, dedicated space and protects the contents against moisture. The T-LOC latch allows you to connect the SYSTAINER to your Festool Sander SYSTAINER, keeping the two together for easy transportation.
The case fits 150mm abrasive discs for Festool RO 150, ETS 150, LEX 2 150 sanders (also suitable for use with non-Festool abrasives). Made of durable, robust, high quality ABS for long service-life; dimensions: 396mm x 296mm x 210mm (L x W x H).
