Fisch
FISCH Elite Eco Auger Bit
SKU: 105934
£9.98 £13.28 Save £3.30
£8.32 Excl. VAT
  • For boring deep holes in soft and hard wood
  • Especially designed for use with cordless drills
  • Low friction coating, deep cut flutes for fast waste removal
  • Threaded tip helps pull auger into timber
  • 320mm overall length, 250mm flute length
  • Made in Austria
FISCH developed these augers for drilling deep holes in soft and hard wood when using cordless power tools. A low friction coating and a threaded tip ensure these augers require only minimum force to perform at their best. Additional relief grooves at the cutting head reduce friction, whilst the deep flutes ensure the fastest possible removal of waste material to prevent clogging. The overall length is 320mm with a flute length of 250mm. They have 12mm hex shanks for non-slip security in a drill chuck. Supplied in a clear, plastic storage tube for protection and easy access.
Drill Bit Diameter 12 mm
Overall Length \ Working Length 320 mm 250 mm
Web Attribute Set Power Auger Bits
EAN Barcode 9002696338666
