Fisch
FISCH Hex Shank Wave Forstner Bits
SKU: 108189
£17.78
£14.82 Excl. VAT
  • Wave style cutting edge gives an exceptionally clean cut
  • 1/4 hex shank for secure and quick tool changes
  • Forged from one piece of high quality tool steel for strength
  • 80mm overall length, working length 55mm
These FISCH Forstner bits have a periphery ‘Wave Cutter’ edge, 2 cutters and centre point allowing them to bore a very clean accurate hole.
The wavy cutting edge virtually eliminates the risk of tear-out, around the edge of the hole. The Wave edge generates considerably less heat and allows cutting speeds to be increased with less effort required to drill the hole.
Forged from one piece of high quality tool steel for extra strength the 1/4 hex shank ensures a very secure fit in a chuck or hex shank holder.
FISCH Wave Cutter Forstner Bits are forged, before being CNC ground and then hardened meaning; accuracy and sharpness are a premium. Overall length of 80mm with 55mm cutting depth.
Made in Austria. Supplied in a clear, plastic storage tube for protection and easy access.
Available in a range of sizes.
Optimum cutting speed;
15mm; 2,400 rpm softwood, 2,000 rpm hardwood.
20mm, 25mm and 30mm; 1,800 rpm softwood, 1,000 rpm hardwood.
35mm; 1,600 rpm softwood, 900 rpm hardwood.
Drill Bit Diameter 20 mm
Web Attribute Set Forstner & Sawtooth Cutters
EAN Barcode 9002696265481
