Fisch
FISCH HSS Brad Point Drill Bit Hex Shank
SKU: 107410
£3.98 £6.98 Save £3.00
£3.32 Excl. VAT
  • 1/4 Hex shanks for use in quick change chucks and keyless chucks
  • High quality HSS brad point drills give clean, fast cuts every time
  • Ground and manufactured from one piece for strength
Perfect for use in cordless drills and screwdrivers with 1/4 hex quick change chucks and offer a more secure fit in a keyless chuck. Made to a very high standard, these 1/4 hex shank brad point twist drills give exceptional clean cuts time after time. For strength, they are ground from a single piece of high speed steel. For a clean, fast cut, the centre point has two cutting edges and two spurs that scribe a very clean entrance hole. The specially ground flute with twin spiral lands quickly clears waste. Suitable for soft and hard woods, laminated boards, MDF and acrylic glass. 1/4 quick-change shank to DIN 3126.E6.3. Made in Austria. Supplied in a clear, plastic storage tube for protection and easy access.
Drill Bit Diameter 4.0 mm
Overall Length \ Working Length 75 mm 30 mm
L1 30 mm L2: 75 mm Web Attribute Set: Wood Boring Bits
EAN Barcode 9002696265337
