Fisch
FISCH Quick Change System 235mm Auger Bits
SKU: 507233
£3.98 £5.52 Save £1.54
£3.32 Excl. VAT
  • Fits any quick change system, including Festool's Centrotec
  • Clean and quick cutting, excellent waste clearance
  • Ground in one piece for strength
  • Fits any hex and quick change system
  • 235mm long
  • Made in Austria
Fits any quick change system, including Festool's Centrotec. Designed for fast clean drilling in cordless drills, these high quality auger bits have our Quick Change System, meaning they will fit into any hex or other quick change system. Suitable for soft and hard wood with a deep gullet to ensure that waste is cleared away from the cutting edge and a threaded tip so that it cuts fast and gives a clean finish. The auger bit is ground out of one piece of steel to ensure precision with high accuracy to give a long working life. Shanks tempered to DIN 3126-E6,3. 235mm long. Made in Austria.
Drill Bit Diameter 10 mm
Overall Length \ Working Length 165 mm 235 mm
L1 165mm L2: 235mm Web Attribute Set: Power Auger Bits
EAN Barcode 9002696296881
