Flex MS 713 Palm Sander 230V
SKU: 114596
£29.98 £44.98 Save £15.00
£24.98 Excl. VAT
  • Quiet-running 220W motor
  • Lightweight ergonomic design
  • Sand wood and paint before finishing
  • Hook-and-loop or clamp fixing
  • Integrated dust extraction system
  • Durable aluminium sanding plate
The Flex MS 713 Palm Sander is your answer to a convenient and compact sander, ideal for general finishing tasks, decorating, furniture restoration and other woodworking. It's light in weight and quiet-running, with a soft grip handle and low-vibration design that improve comfort and reduce fatigue during extended use. The MS 713 delivers up to 14,000 oscillations per minute for efficient material removal and a consistent surface finish, all powered by a 220W motor. The aluminium sanding support plate and dust-proof power switch add to the durability of this professional palm sander. This is a smooth and manoeuvrable palm sander, offering professional performance for everyday workshop tasks.
The Flex Palm Sander includes a dust collection bag and dust extraction adaptor; the integrated extraction helps maintain a clean working environment, while the included adaptor means it can be connected to an external dust extractor if preferred. For abrasives, the MS 713 includes a paper punch for accurately perforating sanding sheets, ensuring optimum dust extraction performance. The sanding plate is 105 x 115 mm and sanding sheets can be secured using hook-and-loop or traditional clamps - whichever best suits the abrasives required for the task.
Flex is a respected German power tool manufacturer, known for producing high performance equipment for professional tradespeople and demanding DIY users, ideal for woodworking, construction and renovation applications.
Supplied with: paper punch, dust collection bag and dust extraction adaptor.
Flex 1 year warranty, extended to 3 years Flex warranty upon registration within 30 days. Benefit from extended 3 years warranty, service certificate in case of repairs, and ability to track repair status while under warranty.
Dust Collection Dust Bag Supplied
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 97 dB(A)
Corded or Cordless Corded
Cable Length 4 m
Sound Pressure Level LpA [Uncertainty K] 84 dB(A)
Motor Power 220 W
Plug Fitted UK 3 pin plug
Web Attribute Set Palm Sanders
EAN Barcode 4030293170780
