Forgefix
Forgefast Elite Torx Countersunk Wood Screws
SKU: 114035
£2.08
£1.73 Excl. VAT
  • Torx®-compatible drive for secure fit
  • Patented thread reduces timber splitting
  • Sharp point pierces 0.8mm steel
  • Elementech 400 coating for 6× corrosion protection
  • Includes Torx® bit; ideal for interiors
ForgeFix ForgeFast Wood Screws feature a universally accepted Torx®-compatible drive for secure and efficient fastening. Recessed ribs ensure superior countersinking while minimizing surface dust, and the reinforced countersunk neck enhances holding strength.
Designed with a patented drill-and-drive thread, these screws reduce timber splitting, prevent ‘jacking’ and spinning of joined timber, and deliver increased pull-out resistance for a firmer fix. The sharp point offers rapid bite and can pierce steel up to 0.8mm thick.
Each screw is coated with Elementech 400, an advanced anti-corrosive finish that lasts up to six times longer than standard zinc coatings. This environmentally friendly coating is free from Cr6+ and has been Salt Spray tested for 400 hours. Sizes 45mm or over have a anti friction thread to help when joining 2 pieces of timber together.
Ideal for interior applications, every box includes a Torx®-compatible bit.
Box Quantity: 200
Pack Quantity 200
Screw Size\Gauge 3.5 mm
Screw Length 12 mm
Web Attribute Set Wood Screws
EAN Barcode 5028485144083
