GemRed
GemRed ExactAngle Meter
SKU: 114211
£13.48 £14.98 Save £1.50
£11.23 Excl. VAT
  • High‑resolution digital angle measurement
  • Excellent accuracy for critical setup angles
  • Dual measurement modes for versatile use
  • IP42 rated for workshop protection
The GemRed ExactAngle Meter is a compact, high‑precision digital angle gauge designed for fast, reliable angle measurement in workshop and site‑based applications. Ideal for machinery setup, blade setting, mitre and bevel work, it provides clear, accurate readings to help achieve repeatable, professional results.
With a fine resolution of 0.1°, the ExactAngle Meter allows precise adjustment and alignment, while its dual measuring capability supports both 4 × 90° and 2 × 180° measurement modes for added flexibility. Accuracy is optimised where it matters most, delivering excellent precision at 0° and 90° for setup‑critical tasks.
Built with practicality in mind, the meter features IP42 protection, offering resistance to light dust and moisture commonly encountered in workshop environments. Its compact form makes it easy to position, carry, and store, making it a dependable everyday measuring tool for woodworkers, engineers, and technicians.
Specifications
Resolution: 0.1°
Accuracy at 0° & 90°: ±0.1°
Accuracy up to 89°: ±0.2°
Measuring range: 4 × 90° / 2 × 180°
IP protection rating: IP42
Web Attribute Set Angle Measurers
EAN Barcode 5052511147151
