Laguna
Laguna 18|36 & 24|36 Lathes Riser Kits 75mm
SKU: 111797
£190.00 £280.98 Save £90.98
£158.33 Excl. VAT
  • Raises the lathe height for a more ergonomic working position
  • Reduces strain on your back and shoulders during long sessions
  • Enhances versatility, allowing for larger and more detailed projects
  • Made from durable materials to ensure stability and longevity
Elevate your woodworking capabilities with the 75mm Riser Kits for the Laguna Revo 18|36 and 24|36 Lathes. These kits are designed to raise the height of your lathe, providing a more comfortable and ergonomic working position, which is especially beneficial for taller users or those who spend long hours at the lathe.
The Riser Kit enhances your lathe’s versatility by allowing you to work on larger and more complex projects with ease. By increasing the height, you gain better access and visibility to your workpiece, which is crucial for detailed and precise tasks. This improved working position helps reduce strain on your back and shoulders, making your woodworking sessions more enjoyable and less fatiguing.
Constructed from high-quality materials, the Riser Kits are built to last, ensuring that your lathe remains stable and secure even with the added height. The installation process is straightforward, allowing you to quickly and easily upgrade your lathe without any hassle. Once installed, you’ll immediately notice the difference in comfort and efficiency, enabling you to focus more on your craft and less on physical discomfort.
Upgrade your Laguna Revo 18|36 and 24|36 lathes with the 75mm Riser Kits and experience the benefits of enhanced ergonomics, increased versatility, and improved comfort in your woodworking projects.
Web Attribute Set Woodturning Lathe Accessories
EAN Barcode 5052511135646
